nu zondag !!
Stephan
i'm assembling it in my living room!! started to throw it together then thought better of it. Ordered all the uprated stuff from MB and should have it running mid-august.
spec so far.: TS1 225,
Cylinder head by Worb5
MB inlet manifold+ packing plate,
Yamaha reed,
Mikuni TM32 carb,
race crank,
JL pipe,
17/46 Li150 gears (143kph@8000rpm),
IWIS 81 link chain,
solid 46 tooth crown wheel,
uprated gear selector spring.
AF lightened flywheel.
still don't know wether to cut the bike down though!
Just start out with a skelly if you're not sure, you can always cut down at any later stage, and you'll not regret cutting it later on...
A skelly is just as easy to work on a a cutdown.
