maurice Geplaatst: 11 september 2012 Delen Geplaatst: 11 september 2012 The FLYTECH variable ignition system by PINASCO is the result of a long research and development process aimed at delivering a high-quality, reliable and long-lasting product. The PINASCO FLYTECH flywheel, made with different weights for all models of most common Vespa VNB-GT-GL-PX-50-SPRING-ET3, was made in a new version with starter ring for all Vespa having the electric starter. The weights of the flywheels are 0.9 kg, kg 1.1 kg and 1.4 kg for Vespa Small frame, 1.6 kg and 1.8 kg (electric starter) for all Large Frame. FEATURES -The super light rotor has an internal steel bulkhead which protects both the magnets and the stator in case of crankshaft breakage. -The ballasts are machined from solid, not from tube, they are perfectly well-balanced and zinc-plated. -The flywheel cones, machined from the solid, are prearranged for Piaggio original extractors in order to ease removal. Their surface is nickel-plated to resist weathering action and corrosion maintaining a perfect thread on the inside. -The nylon cooling fan presents an enhanced fin profile aimed at keeping the engine cool even in the worst conditions, by increasing by 20% the air flux. -The die-cast aluminium stator plate guarantees maximum resistance and features a graduated scale which allows even the unexperienced to set the ignition perfectly. 25356831 ACCENSIONE FLYTECH VESPA PX 125-150-200 C/AVV. ELETTR. KG. 1,8 25356832 ACCENSIONE FLYTECH VESPA PX 125-150-200 Ø 20 / KG. 1,6 25356833 ACCENSIONE FLYTECH VESPA 50 SPECIAL Ø 19 / KG. 1,1 25356834 ACCENSIONE FLYTECH VESPA 50-125 PK XL Ø 20 / KG. 1,1 25356835 ACCENSIONE FLYTECH VESPA 125 ET3 Ø 19 / KG. 1,4 25356836 ACCENSIONE FLYTECH VESPA 125 ET3 Ø 19 / KG. 0,8 25356837 ACCENSIONE FLYTECH VESPA 50-125 PK XL Ø 20 / KG. 0,8 25356838 ACCENSIONE FLYTECH VESPA VNB-GT Ø 17 / KG. 1,6 25356844 ACCENSIONE FLYTECH VESPA 50-125 PK XL Ø 20 / KG. 1,4 If you want to learn more please visit our webpage www.pinasco.com Link naar reactie
mr160 Geplaatst: 13 september 2012 Delen Geplaatst: 13 september 2012 Wat ik verwarrend vind is dat ze, als ik het goed begrijp, geen variabel onstekingstijdstip bedoelen, maar een modulair systeem, met een vast onstekingstijdstip. Link naar reactie
sander2110 Geplaatst: 21 september 2012 Delen Geplaatst: 21 september 2012 en euhhh cuanto costa dan wel? Link naar reactie
