maurice Geplaatst: 2 februari 2007 Delen Geplaatst: 2 februari 2007 Voor wie het interesseert, gezien op: http://www.norbsa02.freeuk.com/goffyleds.htm 6/12V Stop/tail lights for vintage/classic cars & bikes We have designed a small printed circuit Lightboard that can be easily mounted inside tail lights and is suitable for most classic and vintage cars and motorcycles. This takes 12 red LEDS for the stop/tail light and 3 white ones for numberplate illumination. The lightboard is only 1 7/16" in diameter (38MM) and mounts on 2 pillars with 3MM female threads. Only 2 small holes need to be drilled in the rearlight to mount it. The original bulb can be refitted later. The existing contact is removed and the wiring exits as normal. Full fitting instructions are supplied with each unit. The tail light output is designed to be brighter than standard for greater safety. Very low current draw, 0.0075A The lightboard can be supplied to suit 6V or 12V and positive or negative earth systems. Now also for 6V AC systems All the LEDs glow red at reduced intensity for the tail light and at maximum for the stop light. As well as stop/tail lights these boards can be used for tail/fog lights, or tail lights on their own. If they are connected the wrong way round they just don't work - they won't be damaged. Each DC Lightboard costs £20.95 6V AC £21.95 When ordering please state + or - earth 6/12V Complete LED motorcycle tail light 6V/12V +/- earth A lightboard supplied fitted inside a pattern Lucas L564 rearlight (as per photo) is available at £25.95. Other LEDs are available, if you don't see it we may still have it. As in many other areas, technology has overtaken lawmaking, so although our LED performance exceeds the minimum lighting requirements LEDs may not comply with all current legislation. Link naar reactie
